drive trims down by itself
tim10034
does anyone have any clue why my drive trims down by itself when im running it in the water??? the boat will be trimmed fine then every so often i look at the trim gauge and i see its all the way down and i will have to trim it back up to get to the middle of the gauge
Re: drive trims down by itself
Your Trim Pump,+,Or your Trim Cylinders are Leaking, Probably Internally.............<br />Engine/Drive Thrust push it Down.......
tim10034
is there any way to fix it or can i just fill up the trim fluid to the resevoir?
Chris1956
Tim, Trim Cylinder leak down may be fixed, but you need to find out what's malfunctioning. The possible causes: Bad piston seal (or rod seal) in one or both trim cylinders or bad trim control valve. <br />If no oil leaked into the water, the rod seals are probably OK.<br />Now to isolate a bad piston seal, haul the boat, disconnect the hydraulic lines for one cylinder and plug them. Pump up the outdrive and wait to see if it leaks down. If so, repeat with the other cylinder. If it still leaks down it is either both cylinders(unlikely) or the trim control valve. At this point it is probably a good idea to engage a professional who can test the trim control valve. <br />PS There are trim cylinder repair kits available for some standard units.
