driveline/pto????
damstarr
I just bought a 76 waikiki 21ft daycruiser minus engine.All sterndrive parts are there (Its a volvo penta) except however it bolts to the flywheel.Its a volvo penta.Newbie so not sure of names.lol.I guess i need a pto? Is this right where can i find one does anyone have a pic????Also the boat had a 351 in it prior,thinking or a 396 or even a 460 going in to it.Do i just get a pto to fit the flywheel/engine of my choice?.Thanks for any input....Daniel
Re: driveline/pto????
Ayuh,... Welcome Aboard,...
That Volvo has #s on it Somewhere...
Find the serial #, or a full Model #,+ Don can probably tell ya what ya Got,+ what you Need...
I gotta believe a 396 or a 460 Ain't in the cards though....
Don S
Post some pictures of what you have, both inside and out.
damstarr
ok reread prior post....still not sure how it bolts to flywheel or what the piece is called and looks like.....is the viration dampner the piece i took a pic of or the piece that bolts to flywheel?
damstarr
and heres pic of the bellhousing, the other piece that goues to the bellhousing and the backside that goes to the flywheel
zbnutcase
That does look like a 460 Ford bellhousing. The problem is 460 marine parts such as exhaust manifolds are getting scarce. As much as I like 'em, I would use a Chevrolet engine.
captmello
#27 in this link is the vibration damper. Do you have that? The splined drive shaft that comes out of the flywheel cover assembly you have fits into the damper and makes the connection to the engine that way.
http://www.volvopentastore.com/Crankshaft-And-Related-Parts-Aq240a-76/dm/*******.467049808--**********.526924708--store_id.366--view_id.316949
From the looks of it you've got quite a project on your hands. Volvo never used a 460 only the 302 and 351. Forget about anything else.
damstarr
thanks capt...yah its a project but its really not that bad.im just gonna stick with the 351 since i already have many parts and the motor mounts and what not.So as far as #27 in that link ..no..that is what im missing.Is this gonna be a volvo only kinda part? Thanks agian you guys are all soooo helpful.
captmello
ya, it's definitely a Volvo Penta only part. It is specific to the ford 302 or 351 flywheel which were used for only 2 years. Here it is...expensive.
http://www.marinepartsexpress.com:8080/mpeCart/details.faces?productId=855694&Go.x=12&Go.y=16&Go=Go
I suppose its still bolted to the old engine. I would suggest seaching on ebay. You may want to contact some of the guys selling used parts to see if you can find one that way.
Before you start buying anything you should be looking into the rest of the drive train to make sure everything else is functional.
We are happy to help but there is a lot to go through before getting that boat on the water. So if your up for it, you could start by splitting the manifold and risers, like I said in your previous thread, clean the two mating surfaces of gasket debris and taking some pics to determine if they are still usable. The Y pipe is also a concern to me.
To be honest, finding a 351 to put in your boat will be one of the easier parts of the project.
