nattyboomboom
- May 13, 2012
- 6
I removed old impellar and driveshaft was removed from lover unit so I could persuade the frozen impeller to come off- On reassembly I dropped the driveshaft into the lower unit but It did not engage the gear-so when you turn it clockwise does not turn the prop-its also a wee bit too high up for the impeller what did I do to cause this? how do I fix it? motor is a Johnson 87 25hp
Thanks, nattyboomboom
