further
- Jun 18, 2009
- 1,034
Just picked up my new to me 2004 Chap Sunesta. Dealer I purchased from was supposed to go through everything prior to sea trial which we did yesterday... During the sea trial, the boat bogged bad and the notorious fuel pump whine ensued... Luckily, they had 5 in stock so they took the boat back and installed a new pump... Put the boat back in the water and all good.
A little more history... Over winter, after I made the deal, I checked on the boat monthly (to make sure all was in order and just to visit), i noticed gear oil leaking at the prop shaft... Told the dealer that the prop shaft seal was leaking. They had their mechanics replace the prop shaft seal and in doing so broke the bearing carrier so installed a new one with new seals. Leak fixed - all good.
So after all this, I get the boat home yesterday and start tearing into the outdrive to replace the bellows (I want fresh bellows and impeller prior to dropping it in the slip for the season). Pull the outdrive off and the thing doesn't look like its been removed in 10 years.... Shame on me for not looking at it closer during the sale but I was getting a good deal and they assured me they would go through it all. Anyway, once outdrive removed, the ujoint bellows had a bunch of gear oil in it. So I decided to check the level of the gear oil and it was all the way to the top of the dipstick - uh oh.... Opened the vent screw and a ton of gear oil came out... The vent screw was jammed and I had to get creative to free it up so that tells me they didn't even open it when they refilled and probably didn't drain the old oil. Very annoying...
Anyway, there is no water in the oil, not milky at all and no metal shavings.... Drive shifted very smooth during sea trial and no abnormal noises. I'm now draining all the oil and will do a pressure and vacuum test but suspect the u-joint/driveshaft yoke seal probably let go do to it being overfilled and leaked into the ujoint bellows.
I've already sent photos and videos to the dealer (i've been documenting as I go along) and he's acknowledged that its not acceptable and has already offered to come pick up the boat and fix it, but my issue is that he is an hour and half away and if I bring it back I'll likely not get it back for weeks due to the time of year. Dealer has been good thus far replacing the prop shaft seal and bearing carrier as well as fuel pump assembly all on their dime...I've got a call scheduled with him later today to discuss and will likely just ask for either a check to cover the costs he would incur for doing this work and attempt to do this myself or for him to send a mechanic here to do the work (which is unlikely, but I can hope).
So question is, how difficult is it to replace this seal? Straight forward? The alignment is also off... Gimbal bearing seams to be ok though... but I may change it out anyway to be sure.
Sorry for the long rant... Thanks for the input in advance.
