Driving me crazy - electrical problem with Volvo
So, have been battling with the boat for the last 2 months. I've done work, had work done, and am about at my wits end.
Scenario is, boat is not running but certainly in neutral, turn the key to the "run" position and get the audible alarm (beep, beep) telling me that everything should be good to go. I move to "start" and nothing.
This has happened a couple of times; sometimes after getting onto the water, sometimes can't even get off the trailer.
So far i have:
cleanned and replaced all leads to the battery
changed the starter and solenoid
checked all exposed connections to make sure that there were no loose wires
Anyone have a list of "common" electrical problems that i should start with??
Thanks in advance.
QC
Re: Driving me crazy - electrical problem with Mercruiser
The start/key switch?
QC
Dang. I was looking for that. Thanks FT!
Will work through the linked thread - not sure it's the start key switch because i'm getting the warning acknowledgement. If it were that i'd expect that it wouldn't even respond to the switch to the "run" position. Thanks for the link!
Volphin
Need engine and year to even begin to guess....
2002 Chaparral Sunesta 242
Engine is of the same vintage 5.0 GXi
Thanks for your thoughts.
kmc
Fun Times
It seems you're engine model is a Volvo Penta?
QC
Just curious how the key switch working in Run position eliminates a problem with Start position? ;)
aspeck
A 5.0 GXi is definitely a Volvo Penta engine. Moved this to Volvo section.
