The Force power
- Feb 3, 2019
- 2,350
Compression reading results;
#1 @ 134 / #2 @ 136 / #3 @ 140 these reading are taken with a different gauge the previous results posted.
Ignition test = good firing at all Cylinders & a good spark jump
Still no drop in RPM's when #1 gets unplugged, so then it can only be fuel related? pump pressure?
Sprayed a quick squirt of brake-cleaner into #1 carb. and it surged!
(DISCLAIMER; this is NOT a good practice & not recommended, just to clarify for the folks that don't know this)
This would indicate to me a fuel-issue, so I adjusted the fuel/air mixture screw to 1&1/2 turn out(from 1&1/8) revved the engine a couple of times to get adjusted.
Would you believe?!? it made it run on the top Cylinder meaning; the RPM's drops down now when I unplug #1
Someone's theory & explanation is greatly valued
