I hear a whining sound which I suspect might be the water pump going bad. I set out out to replace the impeller but am having trouble dropping the lower unit.
I have removed the four bolts and the nut under the zinc trim tab. The lower unit will drop about an inch but them appears to restrained from further movement. I suspect it might be the gear shift linkage. Any ideas?
The engine is from 2003. It is 4 cycle EFI. Serial number OT805459.
Thanks!
Thanks!
