dt 140 choke coil,silinoed valve
norm64
i have an 85 dt 140 i got it with a free boat , when i test started it with muffs on it actually started with some fresh gas,all though it would not start in auto chock mode ,i had to put it in manual, i checked the coil by putting power to it and it works,i can hear it open the valve ,my qwestion is what is it that tells the coil to be energized when the key is turned,is there a sencer that tells it that it is not up to operation temp?
99yam40
Re: dt 140 choke coil,silinoed valve
Not sure about your Suzuki but most chokes operate by pushing in on the key
Switch while in the on or start position.
halas
That is right with the Zuki's as well.
norm64
what would tell the coil to hold the valve open till it dose not need the choke to operate
