dt 25 want to make it a long shaft
themcbrides_1
where can i find the parts or if i can do it to change my suzuki dt 25short shaft in to a long shaft
jl_photo
Re: dt 25 want to make it a long shaft
the cheap way is to buy a dead long shaft motor that is identical. dead engine with no power-head or lower unit should be much cheaper than the individual parts new or used.
you will need at least:
1 spacer if your engine model uses one.
1 long drive shaft.
1 long shift shaft
1 long pick-op tube.
