DT 50 PLEASE HELP
REDBULL
I AM FIXING UP A DT 50<br />AFTER THINKING THAT THE ENGINE SEIZED , IT WAS DISCOVERED THAT THE MAGNITO HAD COME APART , ANYWAY THAT WAS SORTES OUT , NEW RING WERE FITTED AND GASKETS , THE BIKE WILL START, BUT IT ALMOST SEEMS THAT THE BIKE IS LACKING SPARK , MISFIRING ECT . THEN ALL OF THE SUDDEN THE BIKE GOES NORMALLY , IVE REDONE THE CARB , AND CHECKED THE AIRFLOW BOX , AND ALSO DRAINED ALL THE PETROL AND ADD NEW PETROL , BUT ITS STILL THE SAME , ITS JUST THAT MISFIRING , ALMOST LACK OF FUEL , OR LIKE WATER MIXED WITH PETROL <br /><br />PLEASE HELP EMAIL MAIL ME AT ALLAN.PAGE@MACTRADING.CO.ZA
JB
Re: DT 50 PLEASE HELP
What is a DT-50, Allan?
JB
Not a boat, Allan. This is the Boat forum.<br /><br />This forum also says, "not engine topics".<br /><br />But that's only 2 strikes.<br /><br />Let's put this in Non-boating Technical topics.
Nos4r2
Check your ignition timing and points condition if you've had the flywheel off-and check your reed valves.Make sure your gearbox oil doesn't smell of petrol. If it does then your crank seals are blown.<br /><br />I'd bet it's points or sticky reeds.
