DT 85 Suzuki no charge / tilt out
mrn714
Bad at electrical. Running fine, then lights / depth finder went out. Relized that the battory was not charging, stopped, would not start, no tilt, changed 20 amp fuse, between starter to main harness, got started, but no trim tilt, not sure if charging. Trim relays only click when switch trown. I believe it is due to under 12V at the relays, but the motor started. Should I just juce battory and try again?
