Got the boat July 17th , I replaced the sparkplugs ith ygk b8hs-10.. I dont kno the proper gap sizing.
First trial trip If i gave it full throttle or even 1/2 it ould bog then die. didnt seem to want to run over1500rpm
Found out carb as plugged, pulled carbs off soaked them overnight and all parts in fuel and carb cleaner and gas, in the morning I took aersol type carb cleaner and blew thru all that i could,, used a toothbrush and got the rest, then used air compressor to finish the clean. ( i didnt remove the bars and such all three carbs ere left together.
Took the boat out on the next trial run ran GREAT for about 15-20 minutes or there about. Then when i gave it full throttle again it wouldnt die but i gained no speed and the engine sounded and smelled like it was flooding out. If i let off the throttle back to where it was it would run fine again at that speed. or in idle but not at greater throttle than that.
Seems to be excessive gas/oil on the plugs.
I am no mechanic by any means so any help would be great.
the model number for this outboard is 8501 002055 if anyone knows the year of this model please let me know as well..
thx
thx
