I have a 1988 dt85 that will not go above 4000 rpms. I have cleaned carbs, replaced fuel line, quick connect and bubble. Replaced water pump, tach, and TPS checked out good. The motor runs good just will not go over 4K. The oil injection has been taken off and I am using premix. The motor had a 19 pitch prop and I changed to a 17 with same results. Compression test was 135/135/125.
