Freeman1982
- Aug 19, 2020
- 77
I was on the lake yesterday and the boat was running normally and after 10 minutes on the water the water the engine stop running, I tried to get it going never worked, I backed home and checked the fuel pump I have 55 PSI then I checked the spark from the coil. Then I Looked to the code errors I found this code
DTC 113: IAT voltage high. Please help me . I checked online it showing bad intake sensor. Is that could cause this issue ? And where is located ? I have Volvo penta engine. Please see pictures.
