Dual Fuel Tanks
serdafied
I have twin saddle tanks on port and one starboard. i was wondering if there is any way to plumb both tanks into one water seaperating fuel filter? it has two in ports?? can i hook each tank to a port and have one out to the engine? its an outboard engine so there is no return line. just suction. also is there a way to keep the level in the tanks the same?
Re: Dual Fuel Tanks
Ayuh,... You can plumb them to a selector valve, then the filter...
switching from tank to tank allows semi-equal draw-down,...
Drawing from Both tanks at once, Won't Work...
