dual line to fuel pump conversion question
slx12001
I have used all of the normal methods of converting a dual line engine to a fuel pump with great success. My questions is that I have some leaf plates for various engines that don't have the check valve holes machined into the plate. (5.5 hp and 18 hp) Can I just use the newer leaf plate and call it a day or will I still have to block one channel in the case?
Crosbyman
No Title
why not just use the side cover plates as a source of vacum pulsing . the 5.5 has none so no choice in the matter but most other 50s+ engine have inspection cover plates and installing a pump or nipple is no big issue. just close of the pressure nipple behind the carb ...... or am I missing something here ?
F_R
Agreed. Why would anybody go to all the work to go into the reed plate if not necessary? Well OK, so it is necessary on the 5.5.
Crosbyman
No Title
deleted
slx12001
Here is a picture of a 56 10 hp that I did this weekend. I have had good luck with the genuine mikuni fuel pumps under the honda brand. I used the pulse line from the dual tank setup after doing the usual mods. It runs great. There is no room on the inspection plates for a pulse pick up. My next 22ci conversion will be to simply block the factory pressure tube. I always thought it would be easier to simply make a pulse pickup in the inspection cover. I wish the 10 hp had room for one. Anyone know of a mod to install a pulse pickup on a 10hp?
F_R
Fill the bypass cover cavity with epoxy (JB Weld or similar), drill through & tap 1/8 NPT threads.
jimmbo
Should the paint be stripped before the Epoxy is applied?
