Dumb question about prop diameter and interchangability
Mudbugger
I'm far from an expert, but the diameter should be the entire OD of the prop.
I just checked my engine, I took a tape measure from the center of the prop shaft, and measured the clearance up to the cavitation plate (or what ever it's technical name is) to be sure that I could swing a prop 1/2 inch larger than the original.
You must also take into account, the pitch, as that could affect clearance to water intakes, skegs etc.
Mudbugger
Hopefully my answer, didn't make you feel that way. That's just my understanding of it. I'm less than a novice at this stuff.
Sea Rider
Diameter is the total radial circumference of the prop, pitch will never affect any clearance to AV plate, water intakes, skegs, whichever.
Happy Boating
Elkins45
No, you just stated what should have been blindingly obvious to me.
