dumb question on a boat forum...shot gun info
jim phillips
I have a ted williams pump shot gun (made for sears) and need a part for it any one know of a site or a forum that might help me out? i have done a web search but cant find any thing.<br /><br /> thanks
SpinnerBait_Nut
Re: dumb question on a boat forum...shot gun info
lucky jim, what model TW you got?<br /><br />Post that and I might be able to help you out.
John Carpenter
Many were made by Winchester and are the same as the Model 1300. Take it to any gunsmith shop and they should know at a glance what it is.
lakeman1999
Shotgun trivia! :D ! :D -- What/how determines the guage of a shotgun (410 being the only exception)? :confused: Very few hunters, shotgunners know this, I learned it in small arms school, over 50 years ago in the navy. I spent some time, as a prison chaser, working prisoners on hard labor details, and had to go to a special small arms school to qualify, as we carried the 1911 45, and remington 1100 12 guage riot guns. :D :D :D :D :D
lakeman1999
Did you know the answer, don't be ashamed, or alarmed if you didn't, as a lot of experts in the field do not. Except for the 410, which is actually .410 caliber, the guage is determined as follows. you take a pound of lead, and form it into balls with the diameter the same as the diameter of the barrel, and the number of balls you get will be the guage. Example, you take 12 balls of lead the same size as the diameter of the barrell weighs one pound, it is a 12 guage, 16 balls = 1 pound, it is a 16 guage, and so on except for the 410. :D :D I have won a lot of bets with this question, in the last 50 years, but have won very little money. WHY? Because the mentality of many men, is you shoot them a birdy, or bet them a seemingly simple question about their sport/hobby they cannot answer, and they they will not pay up, they will first call you a lier, and if you do not drop it immediatly, they want to fight you, unless they are too weak for that, in which case you do not want to turn your back to them. :D :D :D :D :D :D
jim phillips
SBN IT's a 21-20ga I need the spring for the slide release button. Checked the web sites that the guys listed above with no luck I will have to call them tomorrow and see if they can help over the phone. I had a friend who is a new gun smith reblue and clean it and it looks like new. If I can find the spring now I will be all set
SpinnerBait_Nut
lucky jim, if that is a sears model number 21, it is the same as a Hi Standard model K2011.<br /><br />Don't show anything for a TW model 21.<br /><br />Hope this helps.
jim phillips
Thanks for the help i will check in to it<br /><br /> jim
aspeck
When all else fails, find and "old-timer" gun smith. I have a few of them as buddies and they can remanufacture anything - usually cheaper than buying from a catalog. And the best part, you get to listen to their old stories as they make the part for you - while you watch. I have a great time with these guys! It is worth going to them even if I can make the part myself!
D
DJ
Guest
Lucky Jim,<br /><br />Does it load and eject from the bottom of the breech? If so, it's a rebadged Ithaca.
jim phillips
DJOHNS<br /> I dont understand what you are asking.
D
DJ
Guest
LJ,<br /><br />Do you load the shells from the bottom? Also, does it eject them from the bottom?<br /><br />By bottom, I mean in front of the trigger ass'y.<br /><br />Ithaca's were one of the few that operated that way. They did build some firearms for the Ted Williams line.
jim phillips
Orded the parts today will be here in a week.<br />Thanks for all the help.The guy that reblued it for me has been telling me for the last 6 months that he could not find the parts any where.It would proubly have helped if he LOOKED!!!<br />One phone call and $10.00 and i am back in bussness. Thanks again<br /><br /> Jim
