F14CRAZY
Ensign
- Aug 12, 2008
- 945
Yes, I know, there aren't dumb questions, but this one might be...
Last season the water pump/alternator belt broke on my OMC 3.0L...I could only tell because the voltage gauge was a little lower and I knew the belt was on its last legs. But heck, the engine temp didn't seem to rise at all and even the battery held up fine, and we ran it for like an hour. I've replaced the belt since then but was wondering, if the impeller in the sterndrive can cool the motor, what's the engine mounted pump for? Aren't you screwed if the impeller fails regardless if the engine's pump is operating?
