Dumb Question
braider
While winterizing my '89 Phantom BowRider the other day, I found that the cousin I got it from had removed the p/s cooler and spliced the hydraulic lines together. Will this harm my p/s pump and steering cylinder by not having any cooling ?
HT32BSX115
Re: Dumb Question
Howdy,
It probably got pulled because it started leaking.
You should really should have one. If the power steering fluid gets hot enough it could cause seal failures in the actuator.
Cheers,
Rick
SFT2
Re: Dumb Question
I have a related question. In general, are fluid coolers (PS, oil, etc) oil to water, or oil to air?
And remember, there are no stupid questions, only inquisitive idiots ;)
Re: Dumb Question
Ayuh,.......
Oil to Water........
Your's probably was Frozen from a Bad winterization.......
I Agree,..... Not Replacing it will probably lead to other Failures........
Windykid
Re: Dumb Question
If it didn't need a cooler they wouldn't have put one on.;)
heyttown
Re: Dumb Question
Not necessarily. Some boats did not come with PS coolers standard.
Windykid
Re: Dumb Question
Then those didn't need it. If the engineers decided to put one on, then there was a reason. for example a smaller resivior could need more cooling. Just my two penny's.:)
