Someone once told me the lower unit oil has to be changed by removing the bottom drain plug, as well as the one on the side of the lower unit, draining the oil, and then refilling it by squirting it up into the hole on the bottom. <br /><br />Now, I thought this seemed like a pretty roundabout way to change oil, but today I took the screw out on the side of the lower unit and it did look like it would be hard to get oil in there. <br /><br />So.. what's the proper procedure?<br /><br />1958 Johnson 35HP
