Re: dump question about impellers
yer boat sounds like it may be unsafe. i've got a 72 trihull in my back yard. it's got rotted stringers and probably transom. towards the end of it's time. i was worried about it being safe to operate for fear of it sinking.... yers sounds similar.
like fishermark said. ya need to approach the boat first, then the engine and drive.
as for bellows replacement. i've done one. so not to much experience. it was mostly straight forward though. to do it, ya really gotta have an oem service manual. like most things on a boat though. one thing leads to another. in replaceing my bellows last fall i ended up doing bellows, shift cable and shift cable bellows, (old style shift cable to new), water hose, ujoints, gimble brg., gear end yoke, ft. seal in drive, drive gear brgs. it cost me round abouts 7-800 dollars. that included oem parts and a few tools. but not all the tools needed, as i had to borrow a few(oem mercruiser tools) to get the deed done.
yer speed sounds about like my trisonic trihull speeds. used to be around 43, and got less towards the end of it's days. upper 30's. possibly from water weight and my engine was gettin tired too.
as for the wellcraft with a 470 version engine. avoid it... do a search on 470 engines here on the iboats... a few things good to be said about them, but mostly not... yer 165 L6 is much better engine wise.
the impeller replacement is pretty much regular hand tools and a service manual to do the deed. ya will need a low value in. lb torque wrench though. the back bolt on the water pump cover is about 15 in. lbs. ya don't want to over torque the bolts on it. and there's three different values for 5 bolts on it.
basicly, it sounds like you have what i have. a 70's tri hull which needs a full restore..... and that won't be cheap. and it will be labor intensive.......
