Dunk's Decarb Process
Chris1956
You can use the main tank for decarb, as long as it only has 3/4 gal of gasoline in it, plus oil and seafoam.
Some of the larger main fuel tanks will not pump the last gallon of fuel out, as a guard against water in the bottom of the tank. If your main tank is large, it may be unsuitable for decarb for that reason.
