Duoprop Drain Plug O-Ring
Peter64
I've got a VP 5.7 Gi PLKDCE with DP-S. Serial plate on the drive just says 'DP-S'. Boat is 1997.
Looking for part number for the O-ring on the lower unit drain plug (which is behind the props). My local dealer says there should be another letter after the DP-S (ie DP-SM or such), so they can't ID the part. The serial plate just says 'DP-S', no other letters. Drive serial number is 4112029306, ratio 1.95. On the VP website, I can find a DP-S drive, but it shows the drain plug on the side of the lower unit, not behind the props. Ideas?
QBhoy
Your dealer should know exactly what DP it is. The big clue is that the drain plug is behind the prop. The others aren’t.
