dust/dirt getting in engine
cesandroid
Anybody ever heard of dust or dirt getting into an engine from travelling down grid roads? A machine shop told me this for some models it happens?
so, how are you running your outboard while towing for it to ingest dirt?
I have an outboard manufactured by Gale in 1956 that has been towed up and down gravel roads thru-out northern Wisconsin and the UP for at least the past 35 years with no ill-effects other than needing to wipe the dust from the outside of the cowl.
I have more problems from insects building nests
iggyw1
Ensign
If it's an outboard motor, and dust is getting under the hood of the motor, and getting your powerhead and everything else under it dusty, just get a dust cover made for the motor or a generic dust cover with elastic around the bottom of it to keep the dust out. Simple solution. If it is getting into the engine itself, I am with Scott on his reply. How are you running the motor while towing the boat???
