With the help of this forum I tuned up my dist (thanks Lou) installed a new coil and checked the carb over.
The manual says dwell should be between 27-31. So I had it at exactly 29. I then set the timing to 8 BTDC. Took the boat out and it has ran great. Put another 20 hours or so on it.
I checked the dwell again after the first trip after I did all this and I saw it was at 30. So I took the cap back off and got it back to 29 and tightened the screw that holds the points as tight as I could get it.
Then today I go out and it is running like crap, wont get over 4K RPM. I had an issue today with the fuel tank vent so I just replaced it with another one (hose, see my other threat). I got out the timing light and the timing had moved from 8 to 2 BTDC So, I checked the dwell and it was 33.
I took the cap off and the screw that holds the points is so tight I cant even get it loose. I was using the same flat screwdriver that I used to tighten it last time but I'm gonna have to get a wider one to get it loose so I don't break it.
So I don't see how the points could have moved with the screw so tight I couldn't loosen it to fix them.
Is there any other way this can happen besides the screw being loose? Because its for sure not loose.
Much thanks!!!
Much thanks!!!
