dyno test
dan t.
just wondering,all marine engines have a hp rating,but at what rpm. it would be interesting to see some dyno charts to see what hp and what torque are developed at what rpm
dan t.
Re: dyno test
thanks for the link, good info,I am actualy more interested in carburated models and a comparison between flat tappet and roller cams
dan t.
Re: dyno test
What I would like to know is at what rpm peak torque is reached, in theory this should give you the best fuel economy if you cruise at peak torque or somewhere close to it
TilliamWe
Banned
Re: dyno test
Dan, for a 5.7 you can feel where the peak torque is. Think 3200 rpms. Flat tappet and roller cams don't make that much of a difference. The peak torque in these marine engines is going to be somewhere around 3200-3400.
45Auto
Re: dyno test
Your best bet is a fuel flow gauge. In combination with a GPS it's the best way determine your most efficient cruise. You'll find that drag has a MUCH greater effect on your fuel economy than the location of the max point in the torque curve. Since you're cruising at part throttle your engine is putting out no where near peak torque so it doesn't care what the peak torque could be. In the vast majority of cases you'll find that peak MPG is somewhere between 25-30 MPH, irregardless of the torque curve of the motor.
If you prop your boat so that the max AVAILABLE torque point (it's max available torque cause you're going to be cruising at part throttle, using nowhere near all the available torque) is your most effecient cruise, you're going to be propping your boat to move the power available curve way to the left. It would be the equivalent of locking your car in second gear where the max available torque point and max efficiency point happen to coincide. Although you would be cruising at the max available torque point and getting max efficiency in that gear, you will be giving away lots of potential MPG and speed.
For example, the torque curve on my boat is essentially flat with max torque between 2900 and 3600 RPM (3 ft-lb of torque difference across the spread). Best cruise is at 29 MPH at 2100 RPM, where max available torque is about 10% below peak. But since the engine is not being required to deliver all available torque (unless I hammer the throttle open because I want to accelerate as fast as I can) the location of the max available torque RPM is irrelevent.
Boattest.com has lots of tests with tables of speed and RPM vs MPG. They don't have the dyno charts, but you can see how consistently a few MPH makes a big difference in MPG.
For example, a 2010 Four Winns 21' bowrider with a 300 HP 5.7L MPI (the one in the GM power curves I referenced in my earlier post) gets max MPG at 2500 RPM. Max torque is about 3200. If you run it at max torque RPM you'll be giving away about 10% in fuel mileage. You'll see the same thing on carbureted engines.
180shabah
Re: dyno test
I was going to say that the most efficient RPM for an engine does NOT = the most efficient RPM for a vehicle
BUT
45 explained it much more betterer :D
dan t.
Re: dyno test
Thanks for the input , I will check out the boattest site , some of my intrest was sheer couriosity as I am repowering this winter from 305 to 350 :D
