E/J Lower Unit Oil - Color Change?
Brew2
Was changing the lower unit oil and was unsure if I had enough left in my bottle in my garage, so dropped by my local dealer to pick up a spare bottle.<br /><br />Turned out I didn't need the extra, but I had opened the new bottle just in case I needed it.<br /><br />The oil in the new bottle is a blue color (kinda looks like the color of oil you'd mix with gas). The oil I've always used is sort of a golden honey color. Checked the bottle to make sure I didn't grab the wrong thing, but it definitely is supposed to be lower unit oil. Did E/J change the color of the lower unit oil...or did they put the wrong oil in the bottle?<br /><br />Thanks,<br /><br />Brew
rolmops
Re: E/J Lower Unit Oil - Color Change?
Oil comes in many different colors.It is the numbers that count.If the oil is the same number and thickness,who cares about the color?
