E Z Loader Trailer Spindel
Red 52
Grease go's in bearing buddy and comes out hole on other (inside) end of spindel. Is that grease going through both outside and inside bearing and then through a bleeder hole between the inside bearing and the seal ? :confused: This is a 1 1/16" and 1 3/8" bearing spindel W/surge brakes.
Bob_VT
Re: E Z Loader Trailer Spindel
Bearing buddies maintain pressure on the grease and yes it does come out when "overgreased". <br /><br />Bob
jimmbo
What Tyeeyaha is talking about is not a Bearing Buddy. It is called Sure Lube. It didn't the spring loaded ends just end caps with a grease fitting. You pumped these full of grease and after the hub was filled the grease would exit out a small hole in the spindle.
