E235TXCOR Looper or Crossflow
jimmbo
Re: E235TXCOR Looper or Crossflow
I'm sure the Too Thirsty Five was always a crossflow engine and that there never has been a looper rated that horsepower. 225 yes, but not 235
biloxiriver
thanks jimmbo. i keep hearing that two thirsty five statement but i acquired the rig just before hurr katrina and have not really had it out for much time so have put very little gas in it. the confusion to me is that if the 235's were so fuel inefficient why is the onboard fuel tank on the 25 cc boat only 70 gallons, it is the original tank too?
jimmbo
probably that was the largest tank they could fit. @ WOT that engine will burn between 20 and 23 gph
Dhadley
The 235 rating was taken from the flywheel. It's closer to 190 (actual) at the prop. In fact when OMC prop rated the same motor (yes, it's a crossflow) it came out as a 175. That still falls within the 10% rule from NMMA.
jimmbo
I thought it became a 185?
mikesea
and if I'm correct ,trying to check my memory here,the 185 -200 was a small bore engine,3.50 the 175 -235 3.625 bore
emdsapmgr
The large bore was only the 235 from like 81 on, including the 2.6 and the later 175 crossflows in the late 80's, as you mention. The 200's should all be small bore, but should have the high ports like the 235.
jimmbo
Actually 1980 was the year the 235 got the larger powerhead.
