e30dplisc trouble
Swamper1
had engine checked at dealer came up good when scanned,good compression,good spark told to replace injector bottom cylinder not igniting fuel and ball not getting hard just flooding engine and dripping out by prop.Injectors not bad,replaced fuel pump canister assembly which it did need.Getting stumped here because I have spark fuel and compression any help will be greatly appreciated.
What is your motor doing / not doing.----They are proud of those injectors, as in BIG $$ and a replacement injector must be set up / matched to the ECU.
Swamper1
pump primer fuel leaks from prop,almost hydrolocking got compression and spark pull wire running on just top cylinder
Swamper1
worked on outboards up until the etecs,complete rebuilds also this got me stumped
Fuel pump or low pressure lift pump.-----Clear identification must be made.
Swamper1
crazy how getting to much fuel without it igniting with spark in the cylinder may be the lift pump
Swamper1
No I am happy as hell, you was dead on I just wasn’t getting it.The fuel was diverted to the vacuum line. Thanks alot
Swamper1
My comment wasn’t meant the way it sounded, I was a marine mechanic about 15 years ago, now a golf course mechanic.
Swamper1
No I am happy as hell,you were dead on,fuel entering the vacuum line.The post was my train of thought not scoffing advice. I can’t thank you enough,always appreciate good advice and helping others.
The lift pump is operated by crankcase PRESSURE pulses.----And not vacuum.
oldboat1
lift pump may be the cure, but might consider soaking/spraying/brushing injector clearer on the problem injector.
