E70TLEDA Primer Choke
BowPro
Is there a rebuild kit for the existing primer choke I have, or do I need to just buy the whole new part? It appears the replacement part number used to be 0437238, but now replaced by 5007356. It leaks fuel. If there is a gasket rebuild for this, I'd rather just do that, but I can't seem to find one. If they are available, a link would be appreciated. If not, are the cheap aftermarket primers any good or do I need to go with the OEM?
BowPro
You beat me to it.----I would use the factory kit myself.----Fairly easy to do.
BowPro
Yes Sir, it looks pretty simple. It's hard to determine what OEM is, being that nothing visibly says so. I see a Sierra brand here on Iboats, and also Sierra on Amazon. Do you think this would suffice? If you have a suggestion, or a direct link to an official OEM kit, I would appreciate it. Thank you.
https://www.iboats.com/shop/sierra-...MIh4Gzufmw_gIV5CdMCh29OQNQEAQYAyABEgI14vD_BwE
https://www.amazon.com/Sierra-Inter...ocphy=1026489&hvtargid=pla-450442786041&psc=1
Your local BRP dealer will help you.----evinrudeparts.ca----- and others can help you.----Amazon generally does not have mechanics on the computers or the phone help line !
BowPro
Good deal. I pulled up the part numbers off the evinrudeparts.ca and just bought the OEM stuff from crowleymarine. I appreciate it.
