ealy vs late 4.3lx vortec
benzurin
I have a '94 4.3lx vortec 4bbl any advantage to go to new style heads? Will my 12 bolt intake work with the 8 bolt heads considering they are both vortec?
Don S
Re: ealy vs late 4.3lx vortec
Nope<br />Bolt pattern and bolt angles are different.
Ayuh,.........<br /><br />The Only Thing about Your motor that's of the Vortec Technology,....... Is the Name........<br /><br />Your motor is actually a Pre-vortec bolt pattern.......<br /><br />I'm Hoping to see 10/15hp from the Swap...... ;)
Don S
Just so our 2 posts aren't confusing.<br />If you change to the new style heads, you need the new style manifold to go with it.<br />The bad part about it, that 10/15 hp gain Bondo mentioned, MAY get you 1 (one) additional MPH for all that expense.
Originally posted by Don S:<br /> Just so our 2 posts aren't confusing.<br />If you change to the new style heads, you need the new style manifold to go with it.<br />The bad part about it, that 10/15 hp gain Bondo mentioned, MAY get you 1 (one) additional MPH for all that expense.
Ayuh,....... Ya need All the Parts to make the System,..........<br /><br />I'm just an old Motorhead,..... Not a Tech.............<br />But,........<br />I Still Know that Pennies add up to Dollars............... ;) :D <br />And,..<br />Tuning is Everything................... ;)
