I believe the Cone Shaped, Slotted, thing-a-ma-jig (lack of a better term, don't judge me) on the early 50's Gale Carbs is slotted to adjust/sync the timing advance to the carb opening. The problem is that is does not seem like it readily turns. I am afraid of breaking it off. The cam thing-a-ma-jig that varies the venturi opening seems to be plastic. It is definitely black but I am unsure if it is plastic. The question is; is it meant to be hard to turn and should I just turn it? I have sprayed it down with wd-40 several times.
