Early 70's Pre Alpha Trim Pump
NicksterFL
Which wires would I jump to raise the outdrive on this early pre-alpha trim pump?
Right now the trim goes down, but solenoid just clicks when going up. I need to raise it to get the boat on a trailer.
I only see one solenoid, so I'm assuming I have this setup. I do have the three button control at the front. The trim limit switch has already been bypassed.
Ayuh,..... Green grass is down, Blue sky is Up,....
