early 80s yamaha 115 spark issue
ralstoner
I hav a mid 80s yamaha 115 b4 runs great great compression and everything except u dnt know whether or not it will start depending on the day and time. I can use the boat all day and the next morning it will hav no spark. But if I leave and come back crank it over it will fire right up Jst currious on what I could be. Iv messed with the harnesses and wires also bi passed the kill switch and that doesn't affect anything it has spark when it wants to? What could this be thanx Ryan
Capt Ken
Re: early 80s yamaha 115 spark issue
Open the CID box on the side of the engine and check the white wire for grounding with the key in the on position.
99yam40
you will have to test things when you have no spark to see what the problem is.
No idea what a 115b4 is
ralstoner
Sorry its a 115 v4 yamaha out board. All ill giv that a try. But usually when I decide to start messing with it then it fires rite up. Thank you
