Earmuffs & Peeing
Bo2255
Started my 2010 etec 90hp. today on the trailer with earmuffs, ran it in neutral for about 45 seconds, no tell tail, no peeing so I shut it down. Was that long enough??Read its bad to run if not peeing. New to boating, asked a question last week got some helpful info. Thanks again in advance.
909
Even if you run the impeller dry for a few seconds , you can damage it. Another reason why I hate muffs. Submerge the impeller.
Crosbyman
on my 75hp I always use the rear hose conection
it backfeeds water via the VST EMM evetually back into the water pump .
just keep the water pressure down when you do so
no need for risky ill fitting muffs
  • ETEC water flow.pdf
mike_i
Ensign
Do you know how old the impeller/pump is? You may have already fried it but if you don't know how old it is you may want to replace it anyway. Next time run the motor in a tank like a trash can where the water level is above the pump level. Also you can shove a stiff wire in the pee hole to make sure there's nothing plugging it up.
ThomW
Could also be something as simple as bugs building a nest in the tell tale hole. You can try taking a piece of weed whacker string and fishing it up through the tell tale hole and see if it is blocked up.
KXP
Ran a 40 hp 4 stroke on muffs no pee put it in barrel and started peeing immediately, never had that happen before .
Ronniewhite
I've had my motor not pee sometimes right away on mufs sometimes it's right away and sometimes it takes a few seconds I don't know why. Tank is definitely better.
