Re: earth ground?
Bushrod.. I would first contact Furuno to get the info directly from them before doing anything else...<br /><br />The directions may be refering to connecting the fishfinder to a boats bonding system which many small boats do not have, especially on boats with outboard motors... So that "earth ground connection" may just end up being connected to a negative terminal, or Furuno may inform you that you may need to add a grounding plate to your boat...<br /><br />A bonding system basicly ties in all of a boats underwater metal parts like thru-hull fittings, running gear and so on to the negative side of the battery to help protect underwater metals from electrolysis and to protect from lightning strikes...
