easy release of tilt and trim ???
I am trying to pull boat out of water, elec goes out and motor in down position. motor has a longer fin on bottom underneath propeller. it will drag and rip everything. How do we release tilt and trim to manually lift motor?? 125 hp force. 1987
roscoe
Re: easy release of tilt and trim ???
OK, sit down and take a deep breath.<br />I don't think there is a manual release valve on that model.<br /><br />You will likely have to remove 1 or 2 hydrolic lines from the pump assembly.<br />Then raise the motor by hand and brace it in place with a 2x4 or other suitable object that can be secured in place.<br /><br />Sorry to bring you the bad news.<br /><br />Someone will correct me if I am wrong, and I hope that I am.
Realgun
Roscoe I think your right its a sucky design.<br /><br />I can get my tilt to work but the trim is messing things up for me. I have tried and tried to fix it but its still leaks down.
look at the bottom of the pump, mine has a white screw there. if i pull it loos it goes up by hand. Watch out for some spray though
