Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Do you currently have a prop for this outdrive? If so are there any numbers on the prop...<br /><br />For what it's worth, I'm thinking that a pin type prop for a Volvo outdrive may be the same, but not sure.. <br /><br />Might try to contact Michigan Wheel... http://www.miwheel.com/MIWheel/profile/main.htm
Let's try this again, the last one terminated early.<br /><br />I have the prop, but have not checked it for numbers yet, I'll check that first. Then I'll cary it to a prop shop and compare it to the Volvo props.<br /><br />I appreciate the information.<br />Todd
