Re: ebay knives
STL,<br />this is a good one, but make sure to get the carbon V steel version,and I would get the gut hook model. I have the non gut hook one.<br />
http://www.ltspecpro.com/fixed-blades-master-hunter.html <br /><br />OMC is correct. Go for the carbon steel over stainless.It takes a little more care to avoid rust, but its worth it.Heres another one for general use:<br />
http://www.ltspecpro.com/13rtk.html <br />This is one awesome all around do anything knife.<br /><br />And here is one of the baddest knives around.It looks goofy, but you cant even imagine how well it chops and cuts.You can cut a 1.5 inch sappling down with one wack.BUT, it can be a very dangerous knife if you arent careful.It can take a big hunk of your ankle if you arent careful when you swing it.And as with all cold steel knives,it comes out of the box sharp enough to shave your face with.<br />
http://www.ltspecpro.com/35ltc.html <br /><br />Another cool cold steel product is the "big bore blow gun". If you have ever shot a "swap meet/gunshow/pawn shop blow gun", once you shoot one of these, you will throw the "toy" blow guns away.These things are incredible! They have several different darts availible, but IMO the mini broad head darts work the best.(most accurate)The bamboo darts work good on birds however.It also doubles as a walking stick. Here it is:<br />
http://www.ltspecpro.com/blowguns.html <br /><br />On their site you can also send off for a free <br />DVD. It shows them abusing there kives to no end.It gets a little old after awhile of watching, but it is worth seeing.Do you get the impresson that I like cold steel products?
<br />PS they also make a great fillet knife.Its thicker than most fillet knives,but is easy to get used to.<br />EDIT: All the above knives are available as factory seconds, for a lot less cash.My experiance with the 2nd's has been great. I had no idea why it was a second.
