Ebbtide
glmoore001
Hi. I am on a quest here to find a boat. I am looking at an 1987 18' Ebbtide Fish and Ski with a 1990 Johnson 120. Owner says engine has 150 hrs, oil injection removed by recommendation of Johnson Dealer, but he still has the injection unit. Drivers' seat is rotted, needs replaced, carpet is older and could stand to go, he says no soft decks or transom. Comes with nice trailer, 2 depth finders, trolling motor, bimini top, cover, life vests etc. The boat is very reasonably priced compared to what I have seen in other ads on the same boat.
I am going to look at it soon. Any comments or suggestions? thanks....gary
ezmobee
Re: Ebbtide
Everyone on this site with an Ebbtide seems to be very pleased with them. Anecdotal evidence here also seems to suggest that they hold up a little better to some mistreatment than some other similar year glass boats. Sounds like a great package IF it is indeed not rotted. Check it out carefully.
Texasmark
Re: Ebbtide
I remember the brand. Remember scanning sales catalogs. Came from Louisiana somewhere. Seemed to be a quality product but never knew anyone who had one. Don't know where they are today. Don't know when and if they used composites vs wood (stringers, deck, transom). Biggest problem in older F/G boats is rotten/water logged wood.
How is the seat trashed out..weather, like the boat lived out in the weather....rain and all? Any signs of water standing (water mark up inside of sides, transom)? You "walk the deck" doin't take the sellers word for it. It should be solid with no movement under a 200# person. Take the boat for a test drive. Get out in a pretty good chop and run at or near WOT. Check where the deck meets the hull/sides transom and look for flexing of the joint....look for the floor flexing (rotted stringers). Any signs of movement in these area make it a no-no.
Is there a well in front of the transom with a drain plug? Can you see under the deck back there....open, holes for drainage? If you can see through to the underside of the deck look for rotting problems. Check transom for signs of heavy stress cracks, rotting and all.
Johnson 120 would be a 4 cylinder. Some were cross flow induction and others loopers. If engine is loop charged, it makes a big difference in efficiency, however OMC did a good job of improving the efficiency of their crossflows from the early days. Lower unit oil change with new plug seals a must....no milky or chocolate oil....water in LU and you don't know how it got there, how long it was in there, and how much damage it caused....you don't want to get involved in fixing that unless they give you the thing.
Probably a set of tires wheel bearings and seals are in order; Bearing Buddies a must and a marine grease made for boat trailer bearings. I'd certainly want to know what my "rig" was rolling on.
Good luck,
Mark
glmoore001
Re: Ebbtide
Good luck,
Mark
Thanks for the great post. I am going to look at it on saturday, will report back.....gary
glmoore001
Re: Ebbtide
Oops, boat sold before I got to it..oh well, there are more boats...thanks for the advice...gary
