Hi
I have a reman balance shaft engine.Roller cam,edelbrock 2114 performer manifold ,it bolts down with 8 bolts so I quess the heads are what you call vortec heads,or at least they are of the newer kind.It has full fw cooling and thunderbolt IV ignition set with 12 degrees initial timing.The carb is a reman edelbrock 1409(marine).Edelbrock sells a kit(1485) but its for the older style engine and 2111 manifold,I suspect these settings might be a bit off.
From what ive gathered merc has used the same carb called weber,I tried finding out the original settings for these carbs as I could use it as initial adjustment and take it from there.But could find anything specific.
If anyone have settings or jetting recommendation for this carb and engine compilation I would be very thankful.
