Edelbrock carb.
88 206
Anyone running an ebrock carb? I am replacing engine in my 88 rinker 21ft. bowrider, going with 350 longblock and thinking of using ebrock performer aluminum intake and ebrock carb. should I be looking at 600 cfm or 750 cfm?
Re: Edelbrock carb.
Ayuh,... The 600cfm is plenty big enough...
The Edlebrock Marine carb is a carbon copy of the Merc/ Weber carb...
WSUDERMAN
Re: Edelbrock carb.
I ran the edlebrock roller rockers, performer intake and 1409 marine carb on a 305 that was in a 78' Fourwinns. It ran great! I got the tuning kit as well so i could change things up at Powell. It was super easy to do even on even on the water. I had the jets and metering rods down pretty small so i would think it would be fine for the 350. I was going from the stock 2 brl and it made a huge difference. Actually had to change props - went up 2" in pitch if memory serves. At the time the marine carb by edlebrock was not well known so when I took it to the shop for outdrive work the mech and I had quite a discussion :)
nikon
Re: Edelbrock carb.
I run the 600cfm edelbrock on my 350, had idle issues with the stock carb, this sorted it all out.
88 206
Re: Edelbrock carb.
Thanks for the replys. Looks like I'll be going with the 600 cfm marine Edelbrock.
