How much difference in prop selection would additional 850# make? Is it enought to justify 1 step down in pitch?
Went out to test new engine and 17P (aluminum) prop, but only had 2 adults and 1/4 tank of gas, Im guessing a more typical load would add somewhere around 800+ pounds passengers and fuel etc. I know currrent prop is too small, Im just trying to decide what prop to try next and dont have anything to base the weight effect on.
For reference its a Maxum 2100SR new 5.7 and 4 barrel package. Tested as stated above with 17P aluminum prop and it ran to 4800 (rev limiter) and still had more to go, . Based on how it 'felt' and how much throttle was left I think it would pull a 21P, (maybe 23 with light load) but would rather error on the small side just to keep everything freed up a little. Plus most of our activity involves watersports so top end is not important. I just dont know if 19 or 21 would be the next best try because of weight difference and how much effect the weight would have.
