Effects of prop changes
stevens
Genuinely curious and temporarily confused: what are the common rules of thumb again?<br /><br /><br />Going from an alu prop to the same pitch in SS lowers WOT rpm by approx......<br /><br />Adding cup to a prop lowers rpm by approx ......<br /><br />Going down one inch in pitch increases rpm by ......<br /><br />Going down one inch in diameter increases top end speed by ...... %<br /><br />Going down one inch in diameter increases rpm by ....<br /><br />Going from 3 blades to 4 lowers rpm by ....<br /><br />For a common moderate V-hull, an expected prop slip rate would in the range of ..... to......<br /><br /><br />Thanks for your help!
TilliamWe
Banned
Re: Effects of prop changes
Rule Of Thumb:<br /><br />Buy Trailer Boats Magazine. Last month they had as good of an article on props & their function as you will ever see. Buy it, and save it, and treat it as a handy guide. Laminate it if necessary.
stevens
Thanks - sounds great. Only wish it was available over here. Would it be available online (can't find it on their website), or could someone maybe scan it and post it here?
Maybe 100 or 200rpms......<br />
Depends on "How Much" cupping is added........<br />
About 100 to 200rpms.....<br />
Diameter is determined by the engineer that desgned the prop.....<br />It's Not something that is Changed,..... It depends More on All the other variables that are Designed into the prop.......<br />
Going down one inch i diameter increases rpm by ....
See Above.......<br />
If the Pitch is the Same,........ There'll be No Change...........<br /><br />Think about Pitch,........ You Really have No Choice about the Diameter,......
TilliamWe
Banned
www.trailerboats.com is their website. I get the mag, so I don't know if their guide is available online, but for some reason I think it is.<br /><br />And Bondo's answers are good, but the article in the mag has them all printed out in readable English, (that's a joke, aimed at your typing like you talk Bondo!)
Originally posted by TilliamWe:<br /> And Bondo's answers are good, but the article in the mag has them all printed out in readable English, (that's a joke, aimed at your typing like you talk Bondo!)
Ayuh,............................ :D ;) <br /><br />Atleast I can use Both Hands when I'm Talking,..........<br />Instead of using 1 Finger when I'm Typing ............ :rolleyes:
