Cdn20valve
- Aug 10, 2015
- 48
Hey guys, i had idle and drivability problems with my 1996 merc 5.7 efi setup. after years of troubleshooting and throwing parts at her, I finally ditched the efi for a edlebrock carb 1409 and intake manifold. the boat has never ran better.
However I'm concerned about safety. My boat has two fresh air vents on the rear. one pulls down to lower bilge, and the other one is connected to the bigle fan. I noticed older(carb'd) boats had two vents, one on either side of the gunwales at the rear. one usually faces front, the other the rear. which helps force fresh air into bilge, and clear out bilge air while underway.
should i bother adding a couple vents on the gunwales or leave it alone and just run the bilge fan when idling around.
thanks, Lou.
thanks, Lou.
