ELEC. Starting sys. ?
starsnstripers
Does anyone know if there is suppose to be a solenoid(starter switch) beside the one on the starter On a mercruiser L6 165hp 250ci 1968-1972? I'm going to look at the wiring schematics however I figured someone might know off hand? Thanks.
JustJason
Re: ELEC. Starting sys. ?
well... the starter solenoid should be on the starter. It may have a slave solenoid as well... if it does my bet is its bolted up under the manifold... take a peek there.
it's an old engine.. no telling how many hands have been in there...
and just because you see found it 1 way, doesn't mean it's supposed to be that way.
achris
More fish than mountain goat
sns,
There should be a slave solenoid bolted to the underside of the manifold about the middle of it, as previous poster stated. It will have the battery lead and main 'hot' feed on one post, the lead to the starter on the other large post, a yellow on one of the smaller posts and a black on the other small post.
Chris.....
Bt Doctur
Iwould think that most use a "slave" because of the thin wire used in boats.
without one you might melt the wiring harness.
JustJason
makes the keyswitches last a whole lot longer to.
starsnstripers
Thanks, I see in the wiring diagram it has a slave solinoid within the system. So your right but why? wouldn't that cause more resistance in the system? Seems like if the starter was connected dirrect to the battery it would have more juice than haveing extra wiring and connections? huh?
MikDee
Banned
It seems all marine engines use slave solenoids, even on the power trim/tilt unit, you usually find a couple there also.
Bt Doctur
the battery main is connected to the starter but the solenoid is what makes the battery cable connection to turn the starter. the current required to operate the solenoid is greater than the capacity of the wiring hence the "slave solenoid"
JustJason
see my last post...... using slave solenoids makes keyswitches (and all switches for that matter) last longer
starsnstripers
OH ! I see now the slave is like a reducer deal, key ignition wires to slave and then to starter solinoid. Got it! I guess i'll use one then.:D Thanks
ron7000
Banned
this is not true, and it doesn't quite work that way.
so before everyone starts quoting boats use thin wiring...
there are different types of starters in regards to how it engages the pinion to the flywheel. The old direct drive style starters had the bendix drive, where as soon as you gave the starter power and it spun the pinion would shoot forward. In this case, the starter solenoid was just that, a high current switch. So all you need is the one solenoid (either mounted on the starter or remote mounted) and the wire from the starter switch went directly to it. This type of solenoid draws low current, so you can use 10-20 feet of 14-16 gauge wire from your ignition switch to it and have it work.
late model starters, the PMGR (permanent magnet gear reduction), do not use a bendix drive. instead, there's a fork that slides the pinion to engage/retract it and the fork is controlled by the solenoid on the starter. This solenoid is also an electromagnet. So when you give this solenoid power, it acts as a high current switch to power the starter at 50+ amps but it also consumes a good deal of power itself to move the plunger in it to engage the pinion. For this solenoid, you cannot just wire your starter switch to it with 14-16 gauge wire. There will be too large a voltage drop along it and you'll actually ruin the starter solenoid long before there's enough current to melt anything. For this type of solenoid you also need a slave solenoid, where the slave solenoid has the wire from the starter switch and it draws low current, and the high current side of it has 10-gauge wire coming from the battery going to the starter solenoid and the wire distance is short so the starter solenoid can get full voltage and current to operate properly.
