Trevthefox
- Sep 25, 2018
- 101
I have a 89 7.5 L OMC 460 king cobra.
I've decided to go the electric fuel pump route. I know about installing the Oil pressure switch. I'm more curious as to which electric fuel pumps everyone likes and placement
1) . Should the new electric fuel pump be placement between the fuel tank and fuel/water separator or.....should the pump be placed in between the carb and the fuel/water separator?
2) Should I install a primer bulb to prime the electric pump in case it sits dry for a while?
Also any wiring help would be much appreciated. There's a lot of info out there about oil pressure switches with relays or no relay whatsoever.
Thanks again for reading and any advice you guys may have
