kneedragger
- Feb 1, 2004
- 61
Ok,
I have a 94 4.3 L Alpha one Mercruiser with an electric fuel pump, and a four barrel carb. It has a fuel water seperator mounted about even with crankshaft pulley on the motor(down low), just up stream from the pump.
After sitting for more than 12 hours or after a small trip on the trailer, it is very hard to start. Even if I pump the throttle mentioned in the starting proceedure. The motor turns over fine, and I can hear the fuel pump running after it has been turned over a couple of revolutions. The fuel pump will not "run" when the key is first turned to the ignition position, it has to turn over a couple of revolutions , before kicking on, is it supposed to run when the ignition is on?
It will start and run for a short period of time if pour a little gas in the throught of the carb, but it not stay running. I have removed the hard line from the carb, and noticed that when the fuel pump is "running", it is not pumping fuel.(I know I am being very careful with the flamable conditions)
What I have discovered is, that if I remove my hard fuel line from the carb, and connect a hose, with a funnel, and pour a little fuel into the line and "prime the pump" from the top down, and then reconnect the hard line, it will run fine, and idle fine all day long as if nothing is wrong. Once it has its "morning coffee", it does fine.
I have read this thread http://forums.iboats.com/showthread.php?t=315482&highlight=electric+fuel+pump
and I know my oil pressure switch is working because my oil pressure guage is operating fine. Is there a possibility that a wire is
Could it be my fuel ant-sipon plunger on my tank? Is my fuel pump bad?
Thanks so much in advance!!
